VRay Unhandled Exception
timurkhan
Hi guys,
I recently started learing 3DS Max for my job. Our company sometimes get some rendering jobs for clients. Mostly I have to render out photorealistic interiors so objects (sofas) can be placed into it. My previous colleague bought a lot of interiors and object online. Now that he's gone this render jobs are given to me, the video guy...
Mostly I just have to adjust the interior, the camera and setup VRay to render the scenes. Quite 'simple' :p I already did a few jobs and the clients were happy (enough). But recently our servers got updated and I think 3DS Max went bananas because of that. I could open some project (because of the paths) and now I can't even render scenes. This is a big problem because a client is already waiting 2 weeks for a render. Since I don't have enough technical background in 3D I was wondering if you guys could help me.
I still can't open a few projects but the one I was able to open doesn't finish the render. It starts but after a minute it gives me a Unhandled exception error: compiling geometry. How can I fix this? Reïnstall 3DS Max or is this a project or path error?
Hopefully you can help me fix this issue.
Thanks!
I've attached a log (just the last part because it was very long).
[2013/Oct/16|17:31:06] Updating render lights
[2013/Oct/16|17:31:06] Updating atmospheric effects.
[2013/Oct/16|17:31:06] Updating render effects.
[2013/Oct/16|17:31:06] Scene setup: 21,9 s
[2013/Oct/16|17:31:06] Compiling render instances geometry.
[2013/Oct/16|17:31:06] error: UNHANDLED EXCEPTION: Compiling geometry
Last marker is at ./src/vrenderlight.cpp, line 512: Preparing lights (Light005)
[2013/Oct/17|08:55:25] Stopping frame timer.
[2013/Oct/17|08:55:25] Total frame time: 55480,5 s
[2013/Oct/17|08:55:25] Render() done.
[2013/Oct/17|08:55:25] Entering Close()
[2013/Oct/17|08:55:25] Calling endSequence().
[2013/Oct/17|08:55:25] Entering endSequence().
[2013/Oct/17|08:55:25] Calling renderEnd().
[2013/Oct/17|08:55:25] Calling renderEnd() on render materials.
[2013/Oct/17|08:55:25] Sending RenderEnd().
[2013/Oct/17|08:55:25] Sending RenderEnd() to atmospheric effects.
[2013/Oct/17|08:55:25] Sending RenderEnd() to render effects.
[2013/Oct/17|08:55:25] Sending RenderEnd() to the tone operator.
[2013/Oct/17|08:55:25] Sending RenderEnd() to environment maps.
[2013/Oct/17|08:55:25] Sending RenderEnd() to override mtl.
[2013/Oct/17|08:55:25] Unloading bitmaps.
[2013/Oct/17|08:55:25] Freeing render instances and lights.
[2013/Oct/17|08:55:25] Broadcasting NOTIFY_POST_RENDER.
[2013/Oct/17|08:55:25] Closing DR
[2013/Oct/17|08:55:25] endSequence() finished.
[2013/Oct/17|08:55:25] Sequence timer stopped.
[2013/Oct/17|08:55:25] Total sequence time: 55480,8 s
[2013/Oct/17|08:55:25] Close() done.
[2013/Oct/17|08:55:25] Enabling scene redraw and autobackup.
[2013/Oct/17|08:55:25] error: 1 error(s), 2 warning(s)
[2013/Oct/17|08:55:25] ================================
[2013/Oct/17|08:55:31] Saving to file.
[2013/Oct/17|08:55:31] Saving distributed renderer.
[2013/Oct/17|08:55:31] Saving filter parameters.
[2013/Oct/17|08:55:31] Saving done.
[2013/Oct/17|08:55:34] VRenderer destructor entered.
[2013/Oct/17|08:55:34] VRenderer destructor done.
[2013/Oct/17|08:55:35] ============================================================
[2013/Oct/17|08:55:35] Console closed normally
sometimes when something weird happens to my max file, clearing the notetracks solves the problem.
it's a long run but worth the try. Download and run the script here
(at your own risk! save a backup of your file before trying)
the last time my company updated our server, the issue I faced was that all my material bitmaps had to be linked through the unc path, I couldn't even launch my max file unless it's through the unc path.
to further explain. I used to be able to launch my file from
A:\Project1\filename.max
now I have to launch it through
\\TS-HTGLBC5\share\Project1\filename.max
my point is that maybe the links are messed up? are there any missing maps when you render?
I'm not really sure what they are, I think they have something to do with animation in 3ds max. What I do know is that sometimes when you're working with 3ds max, especially if you imported/ merged some downloaded models, the models may contain notetracks, and it will be added together in the file you're working on.
The main issue I get when there are notetracks is that the saving time takes very long, together with an increased file size. Which is why once in a while I would run the cleaner script to check if there are any notetracks in the file, and clean it. I'm still not very clear of it's function in a working file, that's why I always recommend that you save a backup before clearing the notetracks.
