CPU Cache
guys I'm planning to buy a system but for the cpu I do have a few options that I need to know whether it's worthy buying it or not.
Core i7 - 6 cores
8 MB L3 Cache
12 MB L3 Cache
15 MB L3 Cache
the price gap is quite much.
Does it really make huge difference in performance between 15 MB and 8 MB Cache CPUs for 3d Works and Vray rendering, suppose the frequency is the same ?
is there any 3d and rendering test benchmarks ?
Which CPUs are you looking at, specifically? They're not sold with a cache size option - e.g., you can't buy a 3930 with 8, 12 or 15MB - and I don't think they have a 6-core i7 with 8MB - so you're probably comparing models that have more differences than just cache size.
Ivy Bridge E 22nm
i7-4930k / 6 cores / 3.4 GHz / L3 12 MB / 130 W / LGA 2011 / Turbo: 3/?/?/?/?/5
i7-4960x / 6 cores / 3.6 GHz / L3 15 MB / 130 W / LGA 2011 / Turbo: 1/1/2/3/3/4
Sandy Bridge E 32nm
i7-3930k / 6 cores / 3.2 GHz / L3 12 MB / 130 W / LGA 2011 / Turbo: 3/3/4/5/6/6
i7-3960x / 6 cores / 3.3 GHz / L3 15 MB / 130 W / LGA 2011 / Turbo: 3/3/4/5/6/6
i7-3970x / 6 coes / 3.5 GHz / L3 15 MB / 150 W / LGA 2011 / Turbo: 2/2/3/4/5/5
Westmere micro-architecture>> Gulftown 32 nm
i7-970 / 6 cores / 3.2 GHz / L3 12 MB / 130 W / LGA 1366/ Turbo: 1/1/1/1/2/2
i7-980 / 6 cores / 3.33 GHz / L3 12 MB / 130 W / LGA 1366/ Turbo: 1/1/1/1/2/2
i7-980x / 6 cores / 3.33 GHz / L3 12 MB / 130 W / LGA 1366/ Turbo: 1/1/1/1/2/2
i7-990x / 6 cores / 3.47 GHz / L3 12 MB / 130 W / LGA 1366/ Turbo: 1/1/1/1/2/2
Oh you're right I didnt notice that.
so either 12 MB or 15 MB.
so it's kinda easier to decide now, but the price gap between a 12 MB cache and a 15 MB is huge (about $400), compare i7-4930k (3.4 / 12 MB) with 4960x (3.6 / 15 MB ) !
Does 15 MB cache (only 3 MB Extra) make significant improvement in my 3ds max works and rendering time?
Edited by gabmass
The Westmere chips are older models, they're not as fast (at the same GHz) as current ones. Look at the 4000 and 3000 series. (The 4000 is the newer generation and is a bit faster, at the same GHz.)
Now look at which models you've chosen. There are K and X models. X models are more expensive by default, and they have features for overclockers that other users won't use. Then there are both cache differences and GHz differences. So you see, the price difference is not just down to an extra 3MB of cache memory.
I think with both K and X series, overclocking is possible but I'm curious to know if there are people who have done this successfully and are happy with the result !? do you think I should make a new thread asking about overclocking !? I know it is also highly relative to MB and VGA. also I find it risky ! Imagine your overclocked CPU is rendering for a week to render an animation model. I can't simply trust manual overclocking unless there are official guides ! what do you think ?
btw, These CPUs do not have fan in box so I have another problem to solve, now I have to challenge finding out fan differences !
It used to be risky 8 years ago when you had to qraphite pencil draw on chips to make this possible in extreme cases :- ) (was fun, I can't remember what was that though, Athlon64?..no idea...)
Today,it's breeze, but for paranoid people like me, I still only go for very mediocre (running my 3930k at 4ghz, just because, even though I know everyone is at 4.4-4.5, but meh.. I argument this to myself with stability...)
Athlon XP ;)
I have overclocked every single CPU i had within the last 15 years, some up to 60%. None of them got damaged. Currently i'm running 9 overclocked i7. It is not risky - if you know what you are doing! And watch your temps. Sure, you can damage the CPU or the board with too high or wrong voltages. But there are many guides you can read and official tables from intel with save voltages. (But no "official" guide for overclocking from intel).
And it is not related to the graphics card only in terms of the power draw of the card. So it is only related to the board, the cooling and the PSU (and maybe RAM).
You have to invest some time to inform yourself and to do proper and honest stability testing.
Cache above a certain amount has small to insignificant benefits.
Good example were the i7-3820, a sandybridge EP (Xeon) chip vs. the i7-2600K/2700K, the consumer Sandybridge chips.
The 3820 had 10MB cache, the 2600K/2700K had 8MB.
In most cases the s1155 "smaller" chips were a tad faster due to other optimizations. Cache, past a certain amount doesn't really affect things - at least for the consumer / desktop applications. It might work a lot more efficiently in a server environment (don't know).
Remember, that the cache is actually shared by all CPU cores, so a 3820-10MB with 2.5MB cache/core actually has more than the 3930K with 2MB cache/core. The performance difference per core is untraceable in the workstation workflow.
