Clone Vray Frame Buffer
Terri Brown
Hi guys,
Does anyone know if it's possible to clone the Vray Frame Buffer for comparison renders without cloning to 3DS MAX Buffer? That is, have two Vray Frame Buffers open simultaneously.
I find the switch btwn Vray Buffer's gamma correction and 3DS Max's a bit of a pain.
Thanks
yeah i don't get it. the max one is very washed out.
Color Mapping settings:
Reinhard
Multiplier 1.0
Burn: 0.35
Gamma: 2.2
Affect Background ticked
Preference settings, Gamma & LUT:
Gamma 2.2
Input Gamma: 2.2
Output Gamma: 1.0
I'm not using colors curve correction on my Vray Frame Buffer
I'd also hazard a guess that you aren't viewing the image in sRGB space - you're actually looking at it with a gamma 1 curve in the VRay frame buffer. Check the sRGB button at the bottom of the vFB, that will show your image with gamma 2.2.
Chances are if you've been doing this for a while, you've been viewing all of your images with "incorrect" (it is after all a personal preference) gamma.
Well what you were viewing it as was gamma 1.0, not gamma 2.2. The "horrible" look is down to the fact that you'll have been setting up all of your lighting and materials for a gamma 1.0 render.
The big reason behind using gamma 2.2 is that "your light goes further", for lack of better words. It has more of a real-world falloff, as opposed to gamma 1.0. A big advantage is that whilst the images generally lack contrast, you have at least retained a lot of the information that would otherwise have been completely lost in gamma 1.0 space, which can then be used in post to reintorduce contrast.
It also helps to overcome the challenge of using real-world values with lights. In gamma 1.0 it was very difficult to light a scene without faking it/using invisible lights because the falloff of light was so sharp.
make sure you have Don't Affect Colours (adaptation only) checked otherwise you'll have incorrect results when ticking the sRGB button, and it will look even more washed out.
http://www.davidfleet.com/tutorials/linear-workflow
