Snapshot tool
robramsay
Hi all,
I have an object with sub-object animation (twist modifier). I have constrained it to a path so that as it moves down the path the object starts to twist. Problem is when I use the snapshot tool to create an array of the objects down the path the resulting objects have the exact same twist profile as each other. They should be offset from one another in terms of the twist.
I'm trying to achieve a similar effect as in the attached image where the facade segments gradually twist open and closed. Any ideas?
Thanks,
Rob
Edited by robramsay
