timurkhan Posted October 24, 2013 Share Posted October 24, 2013 Hi guys, I used to work with 3DS Max 2012 until I had some problems. So I installed 2013 version and everything was working again (rendering + scenes). But now the software is lagging. When I try to push the camera in the viewport it takes at least 2-3 seconds until it reacts and then it's starts lagging. It's so bad that I really can't work in this conditions. I thought it was just an update for my graphic card (Nvidia Quadro 4000). I did that but didn't change anything. Also selecting objects, opening menu's (Edit, Tools, etc.) is lagging. I really can't understand what the problem is... Before everything was working really smooth but now... PC specs: Intel i7 3920 3.8Ghz 16GB RAM Nvidia Quadro 4000 Some suggestions what the problem may be? Thanks! Link to comment Share on other sites More sharing options...
AJLynn Posted October 24, 2013 Share Posted October 24, 2013 If you start 3DSMax using Change Graphics Mode, what mode are you in? Link to comment Share on other sites More sharing options...
timurkhan Posted October 24, 2013 Author Share Posted October 24, 2013 If you start 3DSMax using Change Graphics Mode, what mode are you in? How do you start using graphics mode? I tried adding -h. in the target (properties) but this was not valid.. Link to comment Share on other sites More sharing options...
timurkhan Posted October 24, 2013 Author Share Posted October 24, 2013 Found it I'm in Nitrous. Try another? Link to comment Share on other sites More sharing options...
timurkhan Posted October 24, 2013 Author Share Posted October 24, 2013 I tried Direct 3D no changes. OpenGL was even worse... Back at Nitrous now. It's really the whole software that's working slow... Loading scenes (These are heavy scenes though. Whole interiors but it used to work fine) takes long too. If you drag 3DS Max across the screen it lags too in the beginning. Link to comment Share on other sites More sharing options...
meherthakker Posted October 27, 2013 Share Posted October 27, 2013 do you have the service packs installed ? Link to comment Share on other sites More sharing options...
timurkhan Posted October 28, 2013 Author Share Posted October 28, 2013 do you have the service packs installed ? How do I check this? Can you please send me a link? Do you mean Windows Service packs? Thanks you! Link to comment Share on other sites More sharing options...
meherthakker Posted October 28, 2013 Share Posted October 28, 2013 here you go http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9241178 Link to comment Share on other sites More sharing options...
timurkhan Posted October 28, 2013 Author Share Posted October 28, 2013 I've just installed Autodesk 3ds Max 2013 Product Update 6 and it seems it's working a little little bit faster xp Not sure if it's like that or just seems like that... I couldn't install SP1 because it was already installed according to the popup. I'm installing SP2 now. I ll keep you updated Thanks! Link to comment Share on other sites More sharing options...
timurkhan Posted October 28, 2013 Author Share Posted October 28, 2013 I've installed the following packages: - Autodesk 3ds Max 2013 Product Update 6 - Hotfix - Issue reading CATIA V5 R21 SP2 and SP3 CATPart files - Autodesk Composite 2013 Service Pack 2 I think I have less lag but 3ds max is still lagging. Any suggestions what else it could be or what else I have to install? Link to comment Share on other sites More sharing options...
timurkhan Posted October 29, 2013 Author Share Posted October 29, 2013 I've managed to do a render with Vray but it took a lot more time than usual... When I was adjusting my camera the software was still lagging but it was less than in the beginning. Some more advice? Thanks! Link to comment Share on other sites More sharing options...
AJLynn Posted October 29, 2013 Share Posted October 29, 2013 Have you tried Autodesk technical support or contacting your Autodesk vendor? Link to comment Share on other sites More sharing options...
