TomD_Arch Posted October 29, 2013 Share Posted October 29, 2013 I have a plain in elevation and I wanted to reset the pivot point to the bottom of the plain and I could then set the object to zero elevation. I then expected if changed the height the plain would grow taller or shorter, but the bottom would stay anchored at zero now that I've used Heirarchy>Pivot>Affect Pivot Only. Instead what happens is the plain transforms via the center still, growing or shrinking in both the z directions at once. I don't ever recall this happening before. Can someone make any suggestions? What don't I understand here? Link to comment Share on other sites More sharing options...
heni30 Posted October 29, 2013 Share Posted October 29, 2013 It seems like the pivot point works with transformations; not with changing the height with original creation text imput. If you scale it it will work, figuring out your scale %. You can move the vertices up by typing in an amount in the z direction or manually by rolling the text spinner. You can align the vertices to an object of your desired height. Link to comment Share on other sites More sharing options...
Tommy L Posted October 30, 2013 Share Posted October 30, 2013 The plane is a parametric object. If you want to scale it numericaly then you would collapse it to a poly then move the pivot point then scale. Link to comment Share on other sites More sharing options...
