max 6 file link, 2nd attempt
mauarduz
Q#1.- When loading MAX 6, the splash screen shows the FILELINK.DLU loading as a plugin ?, so is the function hidden, why is this ?
Q#2.- I read somewhere that deleting the mental ray folder (if one uses another renderer) will save a lot lot of memory when loading the program, is this true ??
thank you in advance
Hola Mauricio.
Filelink.dlu is in 3dsmax6 but it works one way only: Import.
No dinamic update for now.
As for the second question, yes, if mental ray is not loaded it will not use memory (how much I don't know, but it is pretty easy to test, backup the folder, delete it and check, you can always restore it) Unless you are very very short on memory I should not worry too much about that one.
Cheers
Edition:
Y Feliz año nuevo!
hey fermí, feliz año nuevo !!!
what would you recommend in case MAX 6 imports 2d DWG so sloppy as the one attached it is really non productive for the work flow to have bad autocad files to start a 3d in max :mad::mad:
such a simple file is corrupted i magine a bigger one
