Best group of scripts for your modeling?
Sourpickles
Hey guys the Marketing company I work for has a TON of in house scripts to make their lives easier on things such as lighting, render settings, spanish tiles, ect...
So now when I do my own stuff at home I feel like Im doing more work then I should haha
I've been gathering a few scripts here in there over the past few months but curious if there were any great FREE ones that you cant live with out while creating your exterior or interior renders.
So far I have floor gen, a spanish tile generator I just found but can't think of the name off hand. It also does fencing and other various architectural geometry and a book gen. I really wish I was allowed to take those work ones home, they have some great ones! :)
so what do you all use that makes your life easier?
Not free, but super cheap: QuadChamfer. Something I can't do without, helps me put ton of chamfers on every single item with ease and leaving me with flexibility of further adjustments. Also QuadCap.
And that's pretty much it, I like to keep my life rather simple than robust. I think most suggested plugins will be those by Neil Blevins and Blur studio but I haven't found much need for them for simple architectural needs.
Obviously I make a lot of my sweeps using the outline of what ever Im provided by my CAD but this is also a nice little tool
http://www.pluginfree.net/2013/11/download-sweeper-for-3dsmax.html
This is the script I found through Facebook (CG Record is a good follow). It has S-tiles and caps as well as fencing and other tiles meshes. Used only for a few mins but makes the s-tile creation a breeze!
http://www.pluginfree.net/2013/10/avizstudio-tools-atiles-201-for-3ds-max.html
zorb - can do everything and is great for large scenes fix up, management and changes
http://www.scriptspot.com/3ds-max/scripts/modifier-modifier-zorb
i suggest making your own workspace with the best tools from Soulburn and Blur packs...there are loads of good ones
other simple useful ones I use...
ID tool
keytransfer
random transform
attachedSelectedobjects
detachSelectedobjects
object replacer
relink bitmap
vray material converter
Ones I use frequently in Max (excluding ones already mentioned..)
CGTools Copy and Paste
Futuregeist Copy and Paste Material
Miauu's Work Plane
Miauu's Nested Isolation
Serge 3 Point Rotation
Zorb Populate Materials
Collins Relink Bitmaps
ecXimer Modifier Clipboard
Clear Layers
Photoshop Selected MAterial
Davis and Goliath Proxy Tool
Advanced Painter
Interactive Renamer
Olly VMC
[/Quote]
random transform +1
detachSelectedobjects +1
object replacer +1
and
Object Dropper
Put Pivot
Pivot to Center (hotkey this one)
Vertex Placer
Soulburn is the first set of scripts to install and is the bare minimum that you should be using.
Ceiling Grid Generator (I know, hate the ACT but architects love that stuff sometimes)
Max Retopo (http://www.scriptspot.com/3ds-max/scripts/max-retopo)
Poly Nurbs (great for cleaning Rhino or 3rd party models) http://www.scriptspot.com/3ds-max/scripts/polynurbs-1-0-released
Spline FFD http://www.scriptspot.com/3ds-max/scripts/spline-ffd
TexTools http://www.scriptspot.com/3ds-max/scripts/textools-toolbox-for-the-texture-artist
PolyUnwrapper http://www.scriptspot.com/3ds-max/scripts/polyunwrapper
Populate Terrain +1
Relink Bitmaps +100000000000
+1 for lots of what has been suggested so far. My additions are:
TIK_QuickPasses - for generating very fast matte/AO/Shadow/Zdepth passes: http://www.scriptspot.com/3ds-max/scripts/quick-passes
Lock/Unlock - Macro for checking/unchecking all those move/rotate/scale boxes for an object's Link Info (great for quickly locking a camera): http://www.scriptspot.com/3ds-max/scripts/lockunlock-link-info
Populate Terrain +1
poly nurbs....
wish i knew about this one years ago!
i bloody hate rhino models in max
  • 4 months later...
wow no ones mentioned Glue yet... that script was fantastic for the current project i'm working on where i had a tiled undulating surface...
used floor generator to create the tiles and glue to attach them to surface...
neil's soulburn scripts are great, i mostly use remove material, remove uvwmap, find instances, detach, attach...
quadchamfer definitely is another frequently used one, as is floorgenerator by cg-source.
