Alvaro Ram. Posted October 17, 2004 Share Posted October 17, 2004 Wach the strange square marks in the window big glasses, it was rendered with vray and the glass is a vray mat. It was rendered irradiance map presests= "high" How can i fix this , or who could share with me , the best setting for these galasses thanks alvstel@adinet.com.uy Link to comment Share on other sites More sharing options...
Jeff Mottle Posted October 17, 2004 Share Posted October 17, 2004 I'm only just learning Vray myself so I'm not altogether sure. What version are you using? If you are using the public beta (1.45.70) did you change the resolution of the final rendered image from the size that the Irrandiance map was rendered at. Somehow I doubt this is the problem, but worth a try I guess. If you did be sure to unckeck "Limit Search Range" Link to comment Share on other sites More sharing options...
voltaire_ira Posted October 17, 2004 Share Posted October 17, 2004 I'm only just learning Vray myself so I'm not altogether sure. What version are you using? If you are using the public beta (1.45.70) did you change the resolution of the final rendered image from the size that the Irrandiance map was rendered at. Somehow I doubt this is the problem, but worth a try I guess. If you did be sure to unckeck "Limit Search Range" try using a vray material.i had the same problem before if i made use of standard mats. also, try increasing your reflection/refraction depth, that may be the cause.or, increase image sampling. Link to comment Share on other sites More sharing options...
Da_RoCk Posted October 17, 2004 Share Posted October 17, 2004 Hi, can u post the settings of your glass so that we can examine it further? Link to comment Share on other sites More sharing options...
Tim Nelson Posted October 17, 2004 Share Posted October 17, 2004 do you have the reflection/refraction 'max depth' checked under global switches. if so, that might be it. I've run into the same problem before on exteriors, even using all vray mats. Link to comment Share on other sites More sharing options...
Life Style Posted October 17, 2004 Share Posted October 17, 2004 Is it divergent surfaces? I get the same effect if I forget to give some depth to the actual glass pane when using the box command. Link to comment Share on other sites More sharing options...
Weider Posted October 20, 2004 Share Posted October 20, 2004 Hi, I think I know the problem. I'm almost sure it's because the width of your glass is 0. Maybe you've created a box or a line and you let the width to 0.0 . Take a look a this, I've already the same problem and it was for this reason. If you really want to have something at 0 of width, you could use a plane, I think it's ok with it. Link to comment Share on other sites More sharing options...
hockley91 Posted October 20, 2004 Share Posted October 20, 2004 I agree that it's a glass with zero thickness. I don't why Vray does that, but it does. I had this problem plenty of times, before I figured it out! Hockley91 Link to comment Share on other sites More sharing options...
jecorona Posted October 21, 2004 Share Posted October 21, 2004 yes.. the problem is this.. tickness 0.. or extrude value 0. or object duplicated.. sorry for my english,.. Link to comment Share on other sites More sharing options...
gayathri Posted November 22, 2007 Share Posted November 22, 2007 My exterior glass is not reflecting the sky. What is the reason? Where to place light for the windows? Link to comment Share on other sites More sharing options...
kippu Posted November 22, 2007 Share Posted November 22, 2007 congrats on bumping a 3 year old thread..... i am sure you will get some replies if you post in a new thread with your images showing your problem Link to comment Share on other sites More sharing options...
