notamondayfan Posted November 11, 2013 Share Posted November 11, 2013 As title, nothing really to worry about, but on my PC pressing "R" doesn't cycle through the scale modes, but on the laptop it does. I thought it was a bug with 2014, but perhaps it's some obscure setting somewhere I've accidentally pressed? Anyone know what I've done? Thanks, Dean Link to comment Share on other sites More sharing options...
Scott Schroeder Posted November 11, 2013 Share Posted November 11, 2013 Do you have your keyboard shortcuts override on? At the top of the Max menu, it looks like a key with an up arrow on it. Make sure that isn't on. Link to comment Share on other sites More sharing options...
benjaminbogaert Posted November 11, 2013 Share Posted November 11, 2013 one other possibility one that occurs to me more then often when u accidentally press alt and shift at the same time it will switch your keyboard layout. Azerty to Qwerty. In that case you just have to press alt shift again. Link to comment Share on other sites More sharing options...
notamondayfan Posted November 12, 2013 Author Share Posted November 12, 2013 Do you have your keyboard shortcuts override on? At the top of the Max menu, it looks like a key with an up arrow on it. Make sure that isn't on. Nope it's always off. one other possibility one that occurs to me more then often when u accidentally press alt and shift at the same time it will switch your keyboard layout. Azerty to Qwerty. In that case you just have to press alt shift again. Never heard of that before, but again doesn't work. Link to comment Share on other sites More sharing options...
Stephen Thomas Posted November 12, 2013 Share Posted November 12, 2013 You might need to go into Customize User Interface and reset the shortcut under the Keyboard tab. That'll show you which, if any, keys are mapped to that command at present. Link to comment Share on other sites More sharing options...
notamondayfan Posted November 12, 2013 Author Share Posted November 12, 2013 Yea I checked that too. When I press R it goes to scale mode, but then if I press R again it does nothing. Link to comment Share on other sites More sharing options...
