Krisztian Gulyas Posted November 21, 2013 Share Posted November 21, 2013 I got a few images and I need to draw the outline of the contents' in 3ds max. Is there a simpler way to do it than drawing point to point in Max? There are too many images to draw them manually and it would take too much time to draw and correct them after dot by dot. I dont need to render these outlines, just to create a plane and give them some thickness, but the real problem is that doing the work manually would take too much time, so if you know an easier/faster method, I would love to hear about it. (I have the PS files). Link to comment Share on other sites More sharing options...
Matt McDonald Posted November 22, 2013 Share Posted November 22, 2013 Do you have illustrator? you could try using live trace to create the paths and then import those paths into max. Link to comment Share on other sites More sharing options...
Krisztian Gulyas Posted November 24, 2013 Author Share Posted November 24, 2013 Thank you. It worked, though I used photoshop to export the paths. Link to comment Share on other sites More sharing options...
