mtutaj Posted October 18, 2004 Share Posted October 18, 2004 Would anyone have a decient off-white granite with dark brown veins? Been looking for a while, can't seem to find anything usefull. Thanks, Mike Link to comment Share on other sites More sharing options...
proces2 Posted October 18, 2004 Share Posted October 18, 2004 are you using VIZ or MAX? if so, try using a multi-level Noise Map. start with a Noise Map, then substitue more Noise Maps into the color channels. Change the values, colors, and noise type (use the 'fractal' type to get the veining effect) at each level. you can get very natural, organic looking textures this way. best of all, with the noise map, its a non-repetitive texture. sean Link to comment Share on other sites More sharing options...
vizwhiz Posted October 19, 2004 Share Posted October 19, 2004 hi There Mike here is a link to a List of Links: Granite: http://www.viz2000.com/html/alfa/materials.html#Granite various Links to look thru, i dont know off of the Top of my pointed head exactly which Link might have "off-white granite with dark brown veins" ** "please note ALL Images are copyrighted of the website et al" ** Try This i hope it goes Thru for you http://www.stoneexpozone.com/p78.php3? forward=192&detail=05406&sname=&slocation=&type=GR&scountry=none&boolean=and&cast=&sstonesim=on&sstandard=on ** how about Marble? http://www.stoneexpozone.com/p78.php3?forward=16&detail=05036&sname=&slocation=&type=MA&scountry=none&boolean=and&cast=&sstonesim=on&sstandard=on http://www.stoneexpozone.com/p78.php3?forward=16&detail=05340&sname=&slocation=&type=MA&scountry=none&boolean=and&cast=&sstonesim=on&sstandard=on http://www.stoneexpozone.com/p78.php3?forward=16&detail=04995&sname=&slocation=&type=MA&scountry=none&boolean=and&cast=&sstonesim=on&sstandard=on http://www.stoneexpozone.com/p78.php3?forward=32&detail=05044&sname=&slocation=&type=MA&scountry=none&boolean=and&cast=&sstonesim=on&sstandard=on ** maybe too low res from internet only check This out it is a CD of hi-res materials http://www.stoneexpozone.com/p170.php3 ICONS2000 1700 Images some more Info about This at: http://www.stoneexpozone.com/p170.php3?detail=2 ** hope This helps, good luck Randy Link to comment Share on other sites More sharing options...
David Barbarash Posted October 20, 2004 Share Posted October 20, 2004 Don't forget about great site for decent res. materials. Link to comment Share on other sites More sharing options...
