Very ODD Flicker in Arch Walkthrough
nitz3D
Hey All,
Hope someone can help me with this. This is the first time i am getting this ODD Issue with walkthrough rendering.
I am attaching a small chunk of the animation.
I am using Vray 2.40.
There is some kind of Texture and shadow flicker happening in every kind of renderings.
I use net render with approx 10 Render Systems for these.
Hope to get some help very soon.
LINK
__________________
Nitesh Srivastava
nthscripts@gmail.com
www.nthscripts.in
looks like it's coming from your environment as it adds an overall brightness increase consistently on the affected frames. Short clip so hard to be certain. It's more obvious in the reflection but it's also affecting the dark red building material which leads me to suspect the environment source.
Check the render logs and see if it's just one specific node that rendered all of the offending frames. If so, that one node likely could not access a file at render time and simply resubmitting those frames to another system will fix it
Hey John Dollus,
Thanks for the reply and suggestion.
I actually tried doing that. But the problem is that its not the particular system thats doing that. I have brighter and darker outputs from same machines and its only happening in some particular textures and shadow areas.
Its annoying and frustrating. I have never faced this problem before.
Here's another one with the same problem.
LINK
Nitesh Srivastava
