TomA Posted November 25, 2013 Share Posted November 25, 2013 Is there a way of replacing frames rendered for an animation, without individually renaming them? For instance if you have a 1000 frame sequence and you want to update only frames 600-700, without changing the names of those frames and replacing them manually? I'm hoping there is a simple and obvious solution but so far I can't think of it. Thanks Link to comment Share on other sites More sharing options...
John Dollus Posted November 25, 2013 Share Posted November 25, 2013 (edited) move the ones you want replaced into a different folder (if you want to keep them for some reason) and resubmit the sequence with the 'skip existing images' option checked on in the render output section. -or- use the Frames area to define individual frames or ranges of frames and submit a new job Those are the quickest ways off the top of my head Edited November 25, 2013 by John Dollus Link to comment Share on other sites More sharing options...
Krisztian Gulyas Posted December 2, 2013 Share Posted December 2, 2013 I usually render the frames with the name "frame_" (how creative ) and max will create a sequence (frame_0001, frame_0002 etc.). When I need to rerender a few frames, i just set the range from (for example) 120-223 and max will replace just those with the same name, in the same folder (frame_0120, frame_0121... frame_0223). Link to comment Share on other sites More sharing options...
Fooch Posted December 2, 2013 Share Posted December 2, 2013 Just patch it over in your post editing program. No need to mis mash haphazard del and type stuff. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted December 2, 2013 Share Posted December 2, 2013 I agree with Fooch, definitely do it in post. Much easier. Link to comment Share on other sites More sharing options...
