wanderer Posted December 6, 2013 Share Posted December 6, 2013 Hi. In the attached image you can see extrusion of holes but i want extrusion of border. Is it the way to implement it without booleans? Thanks. Sorry for noob qustion. Link to comment Share on other sites More sharing options...
Stephen Thomas Posted December 6, 2013 Share Posted December 6, 2013 Did you extrude the solids from a spline? If so it should be a simple case of cloning the object as a copy, go back down the modifier stack to your original spline and attach the border spline. Link to comment Share on other sites More sharing options...
wanderer Posted December 6, 2013 Author Share Posted December 6, 2013 I simply created border line and attached inside enclosed splines from which I want holes to be cut out. I checked shape and found border line is open. Strange, because I welded it before. For some reason I can't weld it.. Link to comment Share on other sites More sharing options...
Stephen Thomas Posted December 6, 2013 Share Posted December 6, 2013 Ah, ok. Maybe check all splines are definitely on the same level first. Failing that you may have to redraw the splines. You could also try doing an edit poly on the splines then extrude or shell to get the height. Link to comment Share on other sites More sharing options...
wanderer Posted December 6, 2013 Author Share Posted December 6, 2013 Well..I found the problem. Lines were imported from autocad and it there were overlapping lines which were treated as a single spline in max. Thanks for your feedback! Link to comment Share on other sites More sharing options...
Stephen Thomas Posted December 6, 2013 Share Posted December 6, 2013 Shape check is a good tool for finding those sort of problems. You can find it under Utilities tab. Link to comment Share on other sites More sharing options...
marius e Posted December 7, 2013 Share Posted December 7, 2013 Shape check is a good tool for finding those sort of problems. You can find it under Utilities tab. Shape check, if it does what it says I will be over the moon!......Stephen, cant believe that I did not know bout that, thanks for the lesson... Link to comment Share on other sites More sharing options...
