Rich O Posted December 8, 2013 Share Posted December 8, 2013 I often get photos from clients taken on all sorts of point n clicks/phones/etc Am wondering what the proper workflow is to match real-world camera settings to V-ray camera settings. eg I have an image from a Samsung Galaxy Note II, the only info provided in the meta-data is that is has a 4mm focal length. How does 35mm equivalent, crop factor, all fit into this? Basically, what are the calculations I'd need to do to put the correct figures into V-ray's camera "film gate" and "focal length" settings? Link to comment Share on other sites More sharing options...
Chris MacDonald Posted December 9, 2013 Share Posted December 9, 2013 (edited) You need to find the sensor size for the note 2 and input that as the film gate, then the 4mm focal length will look correct. [edit] From the info I found doing a quick search, the sensor size on it is 1/3", which is ~8.47mm. Try inputting that as the film gate, then setting the focal length to 4mm. It is worth noting that some of the literature I saw quoted it at having a 3.7mm focal length - best to try both to see which works best. Edited December 9, 2013 by Macker Link to comment Share on other sites More sharing options...
Chris MacDonald Posted December 9, 2013 Share Posted December 9, 2013 My conversion might be off, actually. Based on this page; http://www.gizmag.com/camera-sensor-size-guide/26684/pictures#1 The sensor size (film gate) you want is 4.54mm, not the 8.47mm I suggested. Link to comment Share on other sites More sharing options...
