Render Bucket Problem...seems to be isolated to reflection on multi texure map
danb4026
Hi Daniel,
I've had similar problems that seem to be exclusive to multi-texture maps issues with DR. I tried to get answers on this forum before.... here
http://forums.cgarchitect.com/73317-dr-displacement.html
and here
http://forums.cgarchitect.com/72542-dr-displacement-dilemma.html
I even emailed Thomas at cg-source as I wondered if there were known issues with DR: No reply.
I have no answers unfortunately. I really like the multi-texture map / floor-generator and really like DR, I just can't seem to use both at once.
It may not be exactly the same problem as you're noticing, but I wonder if they are related still.
I say mine might be a similar issue because the displacement affects the light movement off the carpet and, like yours, the problem is subtle; like a small difference in a light calculation between host and nodes.
I should try some more reasoned testing, like rendering out the individual passes to see exactly where the issue occurs, but I suspect that this won't lead me to a cure of the problem, because if it's bust - it's bust.
Have you tried rendering out the individual passes?
