joneberhardt Posted December 9, 2013 Share Posted December 9, 2013 greetings cga members.. so this will be real tricky to explain but i'm going to give it a shot. i set up a standard material - the bmp is jpeg - i copied over to the self-illumnation channel map as well. finally - i use a opacity map. the 1st image shows the result. however - the quality is poor - so i redesigned it at a higher resolution (and as an png) followed the same steps - but there are issues. the resolution is far better - but - you can see that the pattern is random broken up! i haven't a clue why. any suggestions out there? thanks in advance! jon Link to comment Share on other sites More sharing options...
joneberhardt Posted December 9, 2013 Author Share Posted December 9, 2013 sorry for the bad grammar - i meant (jpeg vs png) Link to comment Share on other sites More sharing options...
joneberhardt Posted December 9, 2013 Author Share Posted December 9, 2013 okay - it's resolved.. i increased the intensity of the white areas - and now it renders fine.. the orig was a light grey and rather dull - some reason with that - max/mental ray wasn't picking up all the finer details.. Link to comment Share on other sites More sharing options...
