xjapanese Posted December 10, 2013 Share Posted December 10, 2013 Hi Guys, I would really appreciate if someone can tell me what to do. I have rendered 360 frames for 15 sek animation.in the firs part the jidder interruptions are terrible as I might have moved the camera faster than I should or something that I am not familiar with. What can I do to resolve the problem withour rerendering.I will try the interpolation blending but I don't think it will work ..maybe motion blur or making it faster ...??? Please help if you know how? I need to meet my deadline Here is the animation: Link to comment Share on other sites More sharing options...
Scott Schroeder Posted December 10, 2013 Share Posted December 10, 2013 You can try motion blur, but you'll have to blur it so much you won't see much of anything. If you can't re-render you are better off just starting the image from where the camera moves normally. Or you can hold on a still image the first frame, then fade into the frames that have the camera moving normally. Link to comment Share on other sites More sharing options...
xjapanese Posted December 10, 2013 Author Share Posted December 10, 2013 Hi Scott, Thanks for the advice.I started rerendering the first part.Motion blur wouldn't help ...why is that happening is it just because of the aneven speed of the camera? Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted December 10, 2013 Share Posted December 10, 2013 To me it look like a bad frame rate mix up, Check what's your frame rate in your 3D software, then when import to your video editing software, check frame rate again, 24FPS will look soft in moving object but a little choppy or very blurry if you move fast, 30FPS will look smooth and sharp but you get more frames. What software are you using to create this video? Also your camera has many stops and rotations try to make a more soft movement. That video seems it was rendered at 15 FPS and played at 30 FPS Link to comment Share on other sites More sharing options...
