Please help animation walk through judder problem
xjapanese
Hi Guys,
I would really appreciate if someone can tell me what to do. I have rendered 360 frames for 15 sek animation.in the firs part the jidder interruptions are terrible as I might have moved the camera faster than I should or something that I am not familiar with.
What can I do to resolve the problem withour rerendering.I will try the interpolation blending but I don't think it will work ..maybe motion blur or making it faster ...???:(
Please help if you know how?
I need to meet my deadline
Here is the animation:
To me it look like a bad frame rate mix up,
Check what's your frame rate in your 3D software, then when import to your video editing software, check frame rate again, 24FPS will look soft in moving object but a little choppy or very blurry if you move fast, 30FPS will look smooth and sharp but you get more frames.
What software are you using to create this video?
Also your camera has many stops and rotations try to make a more soft movement.
That video seems it was rendered at 15 FPS and played at 30 FPS
