Sourpickles Posted December 15, 2013 Share Posted December 15, 2013 (edited) Hey guys just ran a 2-3 hour render and my trees are all blotched up. It looks as though the alphas for the leaves are not working? They are the Birch trees I saw on Ronans site and Im using bushes from the free xfrog library. In any case the geometry seems to be showing up and not seeing leaves so Im sure this is the case. I attached the texturight for the trees.....they should be 100% being professional trees and in Vray MTL already. Ideas? Thanks guys! Edited December 15, 2013 by Sourpickles Link to comment Share on other sites More sharing options...
Sourpickles Posted December 15, 2013 Author Share Posted December 15, 2013 did a few tests and 100% its the fact that my opacity map is not working in the Proxies. I am not reading any where that I should be having this issue.....ideas on why? Link to comment Share on other sites More sharing options...
Tommy L Posted December 15, 2013 Share Posted December 15, 2013 Are you sure you have the correct materials assigned to the correct ID's? Could also be a setting in VRay, maybe the transparency depth? Maybe the mapping, are the UVW's on the correct channel? Could be the alpha has different mapping ID. Link to comment Share on other sites More sharing options...
Sourpickles Posted December 16, 2013 Author Share Posted December 16, 2013 hey tom thanks for the reply..... i think....think its actually the proxy levels? i noticed it was at 6.1. i knocked it to 1 and seems to work....or am i nuts? wont render on my home machine now in any case so taking it to work to render on the 32 gb machines Link to comment Share on other sites More sharing options...
