thomastan Posted December 18, 2013 Share Posted December 18, 2013 Hi All, I would like to improve my renderings to look more photorealistics. Could you all give pointers on how I could Improve on it? Link to comment Share on other sites More sharing options...
mohitsanchaniya Posted December 18, 2013 Share Posted December 18, 2013 thomastan said: Hi All, I would like to improve my renderings to look more photorealistics. Could you all give pointers on how I could Improve on it? your render ar good . bt if you improve you material rendering you can imorove the quality for image to fotorealistic . and where ar post production is concered .. send me some high quality images then i would help you out Link to comment Share on other sites More sharing options...
Ismael Posted December 18, 2013 Share Posted December 18, 2013 http://viscorbel.com/vray-materials-theory/ http://www.blenderguru.com/the-1-reason-your-render-looks-fake/ http://3d.about.com/od/Creating-3D-The-CG-Pipeline/tp/8-Tips-To-Increase-Realism-In-Your-Renders.htm Link to comment Share on other sites More sharing options...
Guest dialog Posted December 18, 2013 Share Posted December 18, 2013 Ismael said: http://viscorbel.com/vray-materials-theory/ http://www.blenderguru.com/the-1-reason-your-render-looks-fake/ http://3d.about.com/od/Creating-3D-The-CG-Pipeline/tp/8-Tips-To-Increase-Realism-In-Your-Renders.htm Good Tips Link to comment Share on other sites More sharing options...
thomastan Posted December 19, 2013 Author Share Posted December 19, 2013 mohitsanchaniya said: your render ar good . bt if you improve you material rendering you can imorove the quality for image to fotorealistic . and where ar post production is concered .. send me some high quality images then i would help you out Hi Mohitsanchaniya, could send you my files if you dont mind, what's your email? Link to comment Share on other sites More sharing options...
thomastan Posted December 19, 2013 Author Share Posted December 19, 2013 Hi Guys, Thanks for the links. The attached are the render settings. I wonder I had got somethings wrong? Please Help to see am I doing it correctly? Thanks Untitled-3.pdfFetching info... antitled-3.pdfFetching info... Link to comment Share on other sites More sharing options...
berez Posted December 24, 2013 Share Posted December 24, 2013 1. First off 200 subdivs in light cache is not enough. The bigger resolution of the image is, the higher value should be here. Sample size also should be smaller. 2. Increase dynamic memory limit, unless you really have only 400 MB of memory 3. Noise threshold can't be 0. It can cause even wrong calculation, not mention about waste of time. 4. Don't use antialiasing filter since it doesn't do anything that you can't do in Photoshop better. These filters only restrain possibility of post-editing. 5. Use gamma 2.2 Link to comment Share on other sites More sharing options...
