[Vray] Pink/Hot artifacts
Dmk.
Hello!
I have a problem with rendering, i have this problem first time ever and dont know whats going on.
All materials seems to work properly.
I got house model from revit and build scene on 3ds max.
Maybe someone had this problem before ?
if you received the model from REVIT, mostly you load in your scene Autodesk materials, those are not compatible with VRay.
and the other bad news is the default VRay scene converter does not affect this materials. you need to manually change this materials to VRay, or pay for a material converter that work with Autodesk materials, not to confuse with Arch&Design mental ray.
  • 2 months later...
Hi, how did you get around this issue. I'm having the same problem at the moment. It goes away with iradience map and photon map option, and with the force color clamp.
I also got the file imported from Revit... its a nuisance
At first I thought it was vray physical cam,,, then tried playing with many settings,, so time consuming....
