Guest dialog Posted December 19, 2013 Share Posted December 19, 2013 Just thought I would share with you guys some of the things I have come across while investigating some viewport issues in 3DS Max 2014 and Linking CAD files I am running the new Quadro K6000 on a new BOXX Workstation...this machine is an absolute beast. So, the drivers are up to date, have one of the best graphics cards on the market and I have put 3DS Max to the test. My findings are that linking CAD files proves to completely slows down viewport performance in 3DS Max. Even trying to detach a linked file seems to cause major freezes in 3DS Max. I found that if I import and then group my CAD file, the performance is MUCH MUCH better. Not sure why, but I thought I would share this with everyone to save some hassle and headache in the future. when bringing in CAD files... again, just what I have come across...maybe others have better solutions. Interested to hear... Link to comment Share on other sites More sharing options...
dennispiso Posted January 27, 2014 Share Posted January 27, 2014 Hi Desmond, I have the same issue and was wandering if you found a solution in the meantime? I was having the feeling that it was because i was using a "relative" old GPU. That is the only part i need to revise soon. But now i saw your post with exactly the same issue on quite the setup. Hope to hear from you if you have found a solution. Ciao Link to comment Share on other sites More sharing options...
Guest dialog Posted January 28, 2014 Share Posted January 28, 2014 Hi Desmond, I have the same issue and was wandering if you found a solution in the meantime? I was having the feeling that it was because i was using a "relative" old GPU. That is the only part i need to revise soon. But now i saw your post with exactly the same issue on quite the setup. Hope to hear from you if you have found a solution. Ciao What I did in the long run (after a few different attempts to fix this the short way), was linked the cad and placed it where I needed in my scene. I then "Saved a copy" as for its own file. In that new file I binded it into the scene. Cleaned all the stuff that I didnt need. Grouped it, re-saved and put it all onto one layer. I then used that clean file as an import back into my scene and it completely sped things up. I found either that the linking did weird things sometimes. The viewport seemed to perform much better after if was grouped onto one layer in the new file. Link to comment Share on other sites More sharing options...
