vizwhiz Posted October 20, 2004 Share Posted October 20, 2004 hi There VIZards i got a whomper project, Phase 1 of 5 or 6 has 1002 Plants we are using the "bitmap" flat-plane approach so no RPC's (so far) how do you set-up the 1st Plant to follow the "current" camera?? There will be various cameras within an Interior courtyard corridor and some external site-located cameras from also various points of view and finally i anticipate an animation of all of This at some eventual Time so This means That The various flat-plane Plants will need to face The Camera in different directions for the different renders from The different Points of view i am wanting to do This early and Then clone the Plants following This b4 putting in Tons of vegie-tation and Then having to re-modify Later any help would be greatly appreciated Phase 2, is going to be more than 100 acres, of 220 Total for the Project so far There is only about 9 different Plants Types can you modify plant objects "globally" after They are in place to add the "follow camera" ?? Thanks Randy Link to comment Share on other sites More sharing options...
