yourfather Posted December 28, 2013 Share Posted December 28, 2013 Hi Everyone. I had a rendering solution that worked great and the client approved. But now when i render, the whole image is blown out. My rendering solution: FG (to smooth out GI) GI (to provide the bounced light) But now if i render the image, its too bright. So to test it, i rendered the GI only and this is what i got. See image attached. Render of just the GI solution: GI Settings: Link to comment Share on other sites More sharing options...
yourfather Posted December 28, 2013 Author Share Posted December 28, 2013 Another thing i should let you know is that even if i turn off my daylight system, with no other lights turned on, i get a completely washed out render. This happened after i added a standard omni light. FYI i now have deleted that standard omni but the problem remains. Link to comment Share on other sites More sharing options...
yourfather Posted December 28, 2013 Author Share Posted December 28, 2013 I fixed it. I had to go to the actual folder where the GI map was saved and delete it. But that wasnt enough. First I turned OFF the daylight system. Second I deleted the GI map Third I rendered the scene (the daylight system still off) The result was a dark scene (good, everything working as expected) Fourth I turned back on the daylight system and rendered and everything was back to normal Link to comment Share on other sites More sharing options...
