Splines to surface
Nkony Arch
I have a few splines and I want to create surfaces from them [like the blue one at the top right]
Applying an EditPoly modifier seems to work only at the blue one, and even so there are some problems in the outcome geometry. Does anyone have any ideas on how to create the surfaces?
Thank you in advance!
Thank you Benjamin. I've tried to used that method. But even in the simplest spline of these four, the result...looks nothing to what i want it to be. If you have any other suggestions I would be glad to hear them [or perhaps something I am not doing well with crossection and surface].
Yeah, it is a bit particular about the spline profiles having matching verticies and similar vertex numerical order. There is an option in "edit spline" to show vertex numbers that can help with this when dealing with complex spline networks.
