How To Render Arch Interior plan with low walls with all furniture?(Concept Plan)
NeWAcEiN
Just added what exactly i m after pls help amigoes Thanks!!!!!
Funny to see this post, I just finished something like that. Still needs some post-pro.
Basically what you need to do is make your interior, then add a plane over it right click for the object properties and see that "visible to camera is off" then you just position your camera like in the example and press render. In your example you would apply this on the walls as well ( hide from camera )
In my setup I just used a vray sunlight and used allot of vray plane lights. and in the vray light menu press skylight portal : simple.
Preview_Topview_Watermark.jpg this was the result.
If you still have some questions, shoot and i'l try to help.
hey ben
i did tried plane lights portal trick but not with visible to cam off by adding top plane. and is this is help full rendering Top only or perspective as well? pls Help. also tell me r u using readymade furniture here?? thanks
p.s. the image i added is my render only but as u can see it needs so redoing
Not sure what exactly what your are asking now lol.
The vray lights is just to get enough light in the room. The plane hidden from the camera is just so that your light bounces naturally around in the room. It needs to bounce of the ceiling and back to the ground.
Some of the furniture is bought, but stuff like the kitchen etc I did myself.
hey there
any other settings needs such renders like light and all apart frm plane invisible to cam and all ??
