chrisparrott Posted January 9, 2014 Share Posted January 9, 2014 Hi all, I have a question. I'm trying to create a helix that follows inside the shell of a sphere. This is to create a continuous ramp running from the bottom of the sphere to midway up. Any suggestions? The helix just creates a tapered cone, not a sphere - if you get me. Thanks! Link to comment Share on other sites More sharing options...
Stephen Thomas Posted January 9, 2014 Share Posted January 9, 2014 Well, I like a challenge so here's one solution. Parametric too, so you can go back and adjust to suit afterwards. Step 1 - Create regular helix Step 2 - Add taper modifier, see settings Step 3 - Add spherify modifier Step 4 - Outline spline and delete start and end sections to leave side rails. Make top vertices of both splines no. 1 Step 5 - Add cross section modifier Step 6 - Add surface modifier Done! Link to comment Share on other sites More sharing options...
chrisparrott Posted January 9, 2014 Author Share Posted January 9, 2014 Phwoar! Thanks a lot! A lot neater than what I was attempting (bullions, creating shapes, editing splines - nightmare). Thank you so much! Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted January 11, 2014 Share Posted January 11, 2014 Stephen, you could even make some script if you are good with max scripting? Awesome and clear tutorial! Link to comment Share on other sites More sharing options...
