kris Posted January 10, 2014 Share Posted January 10, 2014 Hi I need to model something similar to Allianz arena facade in 3dsmax. Anyone has some tutorial or suggestion how can i make it so I don't have to model it one by one. Link to comment Share on other sites More sharing options...
Ismael Posted January 10, 2014 Share Posted January 10, 2014 http://torabiarchitect.com/parametric-array/?p=406 Link to comment Share on other sites More sharing options...
kris Posted January 12, 2014 Author Share Posted January 12, 2014 Hi Thanks on your help I have downloaded Para 3d and made some progress using Para3d and tutorial, but I really dont understand 50% of the things I do from that tutorial. The program looks good but it will take some time before i understand some basics. Now my client wants squres vertical and not horizontal like it is in tutorial. Any ideas. Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted January 13, 2014 Share Posted January 13, 2014 You can also make a panel. Then you can make reference copies. Just make one larger surface out of the reference copies. After this you can select the larger surface and add and series of modifiers to get you the form you want. Modifiers like Bend, Taper, or FFD can help form the larger model. With this you can alter the the original panel to effect all reference panels and update the larger model. This is a very heavy way of modelling, but once everything is in place you can just collapse the model and go about your render. I doubt this is the best way to go, but its a native way at least. Link to comment Share on other sites More sharing options...
Scott Schroeder Posted January 13, 2014 Share Posted January 13, 2014 Model it as a flat plane, convert to poly, then using the graphite topology tools you can create the angles. Extrude/bevel/meshsmooth(using various smoothign groups to crease the edges or add in supporting edges) as needed. Then apply various bend modifiers to shape it into what you need. [video=youtube;b6KJOb-r16w] Link to comment Share on other sites More sharing options...
Scott Schroeder Posted January 13, 2014 Share Posted January 13, 2014 To my above post, you might want to make one panel and either use RailClone Pro (the 2d array is only with Pro) or Para3D to move that panel around. This will be the better way as it sounds like your client will want to change the design constantly. Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted January 14, 2014 Share Posted January 14, 2014 If you google "populate panels", you can download the Populate:Panels plugin for max, it has the shape of the panel buildt in as a preset. Just model the basic shape of your building, and make sure it is all quads. It will apply the panel to all the faces that are quads of your mesh, so make sure the quads are the desired size of your panels. Link to comment Share on other sites More sharing options...
