njofra13 Posted January 15, 2014 Share Posted January 15, 2014 Hello, When rendering grass with Itoo Forest Pack Pro, I have problem that every bucket of grass is different color so my grass looks like chess board with different shades of green grass. Does anybody have idea why is this happening? Thnx. Link to comment Share on other sites More sharing options...
cg_Butler Posted January 15, 2014 Share Posted January 15, 2014 Are you network rendering? If so, make sure your network machines can see the bitmaps that are causing your problems. Link to comment Share on other sites More sharing options...
njofra13 Posted January 15, 2014 Author Share Posted January 15, 2014 No, I'm rendering on single pc ... tried to change settings in itoo, try to change setting in vray but the problem keeps appearing ... Link to comment Share on other sites More sharing options...
njofra13 Posted January 16, 2014 Author Share Posted January 16, 2014 The problem was with vray 2sided material if somebody else is having same issues ... Link to comment Share on other sites More sharing options...
paneli Posted March 9, 2014 Share Posted March 9, 2014 The problem was with vray 2sided material if somebody else is having same issues ... Just bought the plugin last week. Never had that issue. How exactly did you solve this? In case I run into it. Link to comment Share on other sites More sharing options...
Jon Berntsen Posted July 25, 2014 Share Posted July 25, 2014 Same here, having some irregular trouble with the 2sidedMtl's. It is a serious flaw, since I need to convert the materials to regular vraymtl's to get predicted results. Did you find any good solutions? I have heard that the problem is not present with vray3, perhaps somebody in here tried and can confirm that? Link to comment Share on other sites More sharing options...
