christophercrocco Posted January 15, 2014 Share Posted January 15, 2014 Hi Ive modeled a renovation of one part of a building. I am now trying to add that model in place of the existing in the picture attached. The model is the part of the building where the roof is shorter and it has the "borders" sign. Ive tried camera matching and i cant seem to get it to work. Any other ideas and step by step directions? thank you Chris Link to comment Share on other sites More sharing options...
Ismael Posted January 15, 2014 Share Posted January 15, 2014 Google Sketchup photo match? Link to comment Share on other sites More sharing options...
christophercrocco Posted January 15, 2014 Author Share Posted January 15, 2014 i dont really know sketch up Link to comment Share on other sites More sharing options...
Ismael Posted January 15, 2014 Share Posted January 15, 2014 Me either but I have heard it said to have a more intuitive Camera match utility than Max. http://cg.tutsplus.com/tutorials/autodesk-3d-studio-max/an-archiviz-workflow-overview-in-3ds-max-sketchup-and-digital-fusion/ Link to comment Share on other sites More sharing options...
Scott Schroeder Posted January 15, 2014 Share Posted January 15, 2014 Max 2014 has a pretty good camera matching utility, though it doesn't appear you are using 2014. An image that simple should be easy to match. You need to make sure you are using nearly the same mm lens in Max as the original camera, you can usually find that in the metadata of the image. You can always fudge the rest into place in Photoshop if you can't get it exact. Link to comment Share on other sites More sharing options...
christophercrocco Posted January 15, 2014 Author Share Posted January 15, 2014 Im using 2011 as stated. The pic was taken with an iPhone 5. Could that be an issue? anyone have a good tutorial? Ive seen so many methods i just dont know what would work best for this scenario. Link to comment Share on other sites More sharing options...
Ismael Posted January 15, 2014 Share Posted January 15, 2014 I stand corrected, max 2014 matching seems pretty good. For older versions maybe try this: http://www.scriptspot.com/3ds-max/scripts/111-cameramatch It seems from the video to be essentially the same as the Sketchup and Max 2014, over and out. Link to comment Share on other sites More sharing options...
