Problem with VrayDisplacementMod
dantrodgers
I am using the vraydisplacementmod on a wall, it works fine in some areas but looks pretty strange in others.
The geometry is just a shelled plane, unwrapped and vraydisplacementmod on top. The problem only seems to happen when the brick is directly facing the camera :confused:
any help would be great. see images for more info :D
at 100%
settings
I havent got the displacement map to hand atm, but its basically just a pure black and white checker(ish) pattern, masked from the original diffuse map.
I have checked the normals, and they were fine. I also checked AO and diffuse passes which also looked fine other than i slightly darker area on the AO where the black border is.
Like you say, I does look like its going inwards though. Or a really shitty optical illusion
