goldychitkara Posted January 17, 2014 Share Posted January 17, 2014 Hi Friends, Attached is an rendered image, all was going well but all of a sudden started getting these red spots on rendering. I am rendering an animated camera on local machine, some of the frames are coming good but some has this issue. Using IR map in primary bounce and light cache in secondary. Pls let me know, what could be the issue, need your help. Regards, Goldy Link to comment Share on other sites More sharing options...
Guest dialog Posted January 31, 2014 Share Posted January 31, 2014 I have had this before. Check your glass materials. We got this issue and it was one small car model that had a bad glass texture. Deleted the model and fixed everything. Is this VRay or Mental Ray? Our issue was Mental Ray... Have never seen it in VRay. If it is VRay can you post your settings Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Piash Posted January 31, 2014 Share Posted January 31, 2014 There must be a material which is not supporting your render engine. I got similar problem before. Adjusting material solved it. Link to comment Share on other sites More sharing options...
dine79 Posted January 31, 2014 Share Posted January 31, 2014 Looks like it is definitely a material problem. Had this issue in the past. Also seen raytrace material in a vray scene do that also. Link to comment Share on other sites More sharing options...
