hoseinasadi Posted January 20, 2014 Share Posted January 20, 2014 after i assigned materials to walls , they turned black and i have no control over the texture in viewport unless i hit render everytime id want to modify them which is not logical at all. im using 3ds max 2010 64bit. is this a software bug ? cant it be fixed? Link to comment Share on other sites More sharing options...
Ismael Posted January 20, 2014 Share Posted January 20, 2014 http://docs.autodesk.com/3DSMAX/15/ENU/3ds-Max-Help/index.html?url=files/GUID-D968CDD9-4C5D-489D-A311-ED7486FCD4AA.htm,topicNumber=d30e387921 "... The viewport updates to show the sub-material assigned to the selected faces. The material ID values in the Multi/Sub-Object material and the material ID numbers in the Select Face rollout correspond. If you set the ID to a number that doesn't correspond to a material contained in the Multi/Sub-Object material, the faces render as black." Maybe that. Link to comment Share on other sites More sharing options...
hoseinasadi Posted January 20, 2014 Author Share Posted January 20, 2014 http://docs.autodesk.com/3DSMAX/15/ENU/3ds-Max-Help/index.html?url=files/GUID-D968CDD9-4C5D-489D-A311-ED7486FCD4AA.htm,topicNumber=d30e387921 "... The viewport updates to show the sub-material assigned to the selected faces. The material ID values in the Multi/Sub-Object material and the material ID numbers in the Select Face rollout correspond. If you set the ID to a number that doesn't correspond to a material contained in the Multi/Sub-Object material, the faces render as black." Maybe that. thanks for the reply, im not using multi/subobject materials for these walls tho. could this be a bug? Link to comment Share on other sites More sharing options...
salvador Posted January 20, 2014 Share Posted January 20, 2014 Try shaded mode instead of Flat. Link to comment Share on other sites More sharing options...
hoseinasadi Posted January 22, 2014 Author Share Posted January 22, 2014 Try shaded mode instead of Flat. no difference. Link to comment Share on other sites More sharing options...
Ismael Posted January 22, 2014 Share Posted January 22, 2014 Maybe the 'Normal' is flipped on the wall or perhaps missing uv map. Link to comment Share on other sites More sharing options...
