Student with budget to match needs a new desktop!
Hi all,
My 2 year old DV6 laptop is starting to show its distinct inadequacies when it comes to modelling and rendering, so have put some $$$ aside to build something more powerful.
I'm currently using or will be using the following programs;
Sketchup
3DS Max
Vray (for both of the above)
Photoshop CS5
Archicad 17
To start with, my budget is around $1500NZD. This could be pushed a little if need be. I don't need any peripherals or a monitor. I have a fairly decent grasp of modelling and vray, but I'm not exactly a full blown pro.
I'm confident with the building aspect, though have never built a PC before.
If anyone would be prepared to give some advice as to what specific parts I should be looking at, that would be great. I see the 4930k retails for around $800 NZD here, so not really looking to go to that sort of extreme :D
Thanks in advance team
I agree that a 4930 build is a little out of your reach but a similar build with a 4770 would serve you very well.
I would recommend something very similar to the build that Dimitris Tolios suggested in post #2. I think if you shop around you can get it within your budget or just above.
http://forums.cgarchitect.com/75386-help-building-desktop-3ds-max.html
idea for a small and silent pc, no overclocking:
Intel Core i7 4770 Boxed
ASRock B85M-ITX
MSI R9 270X GAMING 2G
Fractal Design Node 304
Cooler Master Hyper 412S
Crucial Ballistix Tactical BLT2C8G3D1608ET3LX0CEU
Seasonic G-Serie 450Watt
Samsung 840 EVO 250GB
alternative parts:
Cooler Master Silent Pro Gold 450W
Inno3D GeForce GTX 660 2GB
Gelid Solutions Tranquillo Rev.2
Scythe Mugen 4 PCGH Edition
(Silverstone Sugo SG05-Lite)
Both above suggestions are about right. I think Dimitris should write some sticky note with configs based around 4770 and 4930 since most people will decide just between these too and only fill the remaining parts according to budget.
Few things I like from above post (Joel's) is suggestion of smaller PSU. You can get passive cooled PSU's under
Smaller format cases. The Node is nice and if I would by 4770k myself, I would probably keep it small as well. Small&Silent.
Thanks so much for the replies - I imagine you all must get sick of these sorts of requests, so I do appreciate he time taken.
@ Juraj, hadn't given too much thought to overclocking in all honesty, purely because I'm not particularly educated on the subject. From what I gather, the "k" infers the ability to do just that so it may be $$$ dependant as to what I opt for, ultimately.
If you want overclocking, things will get a litle bit more expensive. K-version processor, mobo for overclocking, better cpu cooler (and maybe a cooler case) will cost more.
Pro's for overclocking:
somewhat higher single core speed
slightly faster render times
Con's for overclocking:
higher temps
bit more energy consumption
I believe it is possible to overclock high with a b85 mobo (this is a mobo not meant for overclocking) and the current haswell k-processor, like i7 4770k.
You can look at the following b85 mobo's without spending too much cash:
Asus Vanguard B85
Gigabyte G1.Sniper B5
MSI B85-G43 Gaming
ASRock Fatal1ty H87 Performance
If you prefer a z87 mobo (this is a mobo meant for overclocking) without spending too much cash:
ASRock Z87 Pro4
MSI Z87-G43
Source:
http://translate.google.nl/translate?hl=nl&sl=pl&tl=en&u=http%3A%2F%2Fpclab.pl%2Fkat2.html
A bigger case without spending too much cash:
Antec GX700
Antec One
Corsair Carbide 200R Closed
Corsair Carbide 300R
Fractal Design Core 3000
Gelid Solutions DarkForce
NZXT Source Elite 210
Sharkoon T28
Thermaltake Chaser A31
Xigmatek Midgard II
Zalman Z9 Plus
Zalman Z9 U3
Zalman Z11 Plus
Zalman Z12 Plus
If you really want to push the cpu to it limits go for a watercooler, like the corsair h105.
If you do a moderate overclock, you can also look at the follwing cpu air coolers:
Thermalright HR-02 Macho Rev. A
Thermalright True Spirit 140
DeepCool Gamer Storm Lucifer
DeepCool Neptwin
Scythe Ashura
Raijintek EREBOSS
Make sure the cpu cooler fits into the case.
If you want to overclock the cpu to its limits and you want a bigger gpu in the near future then also look for a bigger power supply (psu) from seasonic. If you decide to go with a small case, like the node 304, you have to watch out that not all psu's will fit.
If I was to overclock the cpu and stress it a lot I would also go for a bigger and better case with good airflow to keep things cool:
Antec Eleven Hundred
Cooler Master CM 690 III
Corsair Carbide 400/500R
Corsair Carbide Air 540
Corsair Vengeance C70
Fractal Design Arc Midi R2
Thermaltake Urban S41
Do a google search to see the prices. As you see above overclocking ads to the budget. if you don't do a whole lot of rendering and you can wait a few extra seconds you don't need to overclock.
http://www.kitguru.net/components/cpu/zardon/gigabyte-ga-z87x-oc-motherboard-review-w-intel-i7-4770k/17/
http://nl.hardware.info/reviews/4585/2/48-desktop-en-66-mobiele-processors-getest-in-cinebench-115-resultaten
Edited by joelmcwilliam
