hoseinasadi Posted February 7, 2014 Share Posted February 7, 2014 ive tried 3 different methods in order to get reflections from a HDRI map on an object , none of them worked for indoor, however they work perfectly for outdoor. i created a box (like a room ) and placed my object in it , added a HDRI into vray reflections slot , hit render and no reflection from HDRI map , as soon as i remove the box , BOOM! there's reflections from HDRI map. how can i use a HDRI for reflection for indoor renders? P.S : put HDRI in material's environment slot , same problem. Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted February 7, 2014 Share Posted February 7, 2014 Make some windows? Link to comment Share on other sites More sharing options...
Ismael Posted February 7, 2014 Share Posted February 7, 2014 Add the 2 images. Create a billboard and put the reflection map in it. Fake one way or fake another way, it is still a fake. Apparently the Env Slot do not work for interior. Link to comment Share on other sites More sharing options...
neil poppleton Posted February 7, 2014 Share Posted February 7, 2014 Would the natural sky be reflected inside an object inside a closed box on your desk. Link to comment Share on other sites More sharing options...
Scott Schroeder Posted February 7, 2014 Share Posted February 7, 2014 The box blocks your HDRI, as it should. When the teapot in inside the box, it reflects the box. I can tell you with great certainty that as I sit here in the office, the sky outside is not reflecting off my high-gloss coffee mug. Though if I saunter over to the window, hey look at that, sky reflections. Link to comment Share on other sites More sharing options...
hoseinasadi Posted February 7, 2014 Author Share Posted February 7, 2014 thanks for the tips guyz, found a way tho. in the object properties of the box , uncheck "visible to reflections/refractions" Link to comment Share on other sites More sharing options...
Scott Schroeder Posted February 7, 2014 Share Posted February 7, 2014 hoseinasadi said: thanks for the tips guyz, found a way tho. in the object properties of the box , uncheck "visible to reflections/refractions" Right, but then you are going to get unnatural and completely unrealistic reflections in your image. I guess I should have lead with, what exactly are you trying to achieve? Link to comment Share on other sites More sharing options...
RyderSK Posted February 7, 2014 Share Posted February 7, 2014 hoseinasadi said: as soon as i remove the box , BOOM! there's reflections I don't even.. Link to comment Share on other sites More sharing options...
hoseinasadi Posted February 9, 2014 Author Share Posted February 9, 2014 (edited) VelvetElvis said: Right, but then you are going to get unnatural and completely unrealistic reflections in your image. I guess I should have lead with, what exactly are you trying to achieve? to get reflections from my HDRI map while keeping the walls. Edited February 9, 2014 by hoseinasadi Link to comment Share on other sites More sharing options...
Nic H Posted February 9, 2014 Share Posted February 9, 2014 it's almost as if the box was blocking the reflections....if you were to remove the box there will be reflections Link to comment Share on other sites More sharing options...
hadouken Posted February 11, 2014 Share Posted February 11, 2014 this thread is hillarious haha Link to comment Share on other sites More sharing options...
andstef Posted February 12, 2014 Share Posted February 12, 2014 Maybe the intention was not to obtain a photoreal image, in wich case I congratulate M.H. Asadi for the solution to this problem. If they fit the purpose, not all renders need to be photoreal. Link to comment Share on other sites More sharing options...
RyderSK Posted February 12, 2014 Share Posted February 12, 2014 andstef said: Maybe the intention was not to obtain a photoreal image, in wich case I congratulate M.H. Asadi for the solution to this problem. If they fit the purpose, not all renders need to be photoreal. If you re-read his first post, you will absolutely clearly without any other possible intention see that it wasn't the case. I understand your kind knightly intention to defend this poor soul but really, you just made this up. His writting is absolutely clear, there is nothing other to decipher. Link to comment Share on other sites More sharing options...
