jonathanwiederin Posted February 16, 2014 Share Posted February 16, 2014 Hi guys it seems to me that i`m stuck and can`t increase my render skills at the moment. if you could give me some advice or ideas on how i can improve my skills i would be very thankfull. What i think would be important: increasing level of detail: learning how to light better some pictures have not enough contrast working with hdri? would that increase level of realsim? Link to comment Share on other sites More sharing options...
renderingdesigner Posted February 16, 2014 Share Posted February 16, 2014 Hi, try to increase reflections in all objects (all materials shoud be reflective in differente amounts), ie, wood should cast some blurring reflections. Try to increase surface contrast usinng or reinforcing the occlusion pass. Try some photoshop filters and post treatment. Regards Link to comment Share on other sites More sharing options...
Ismael Posted February 16, 2014 Share Posted February 16, 2014 (edited) http://www.neilblevins.com/cg_education/linear_non_linear_visual_difference/linear_non_linear_visual_difference.htm http://www.neilblevins.com/cg_education/cg_education.htm http://3d.about.com/od/Creating-3D-The-CG-Pipeline/tp/8-Tips-To-Increase-Realism-In-Your-Renders.htm http://www.dezeen.com/2013/08/12/henry-goss-on-architectural-visualisations/ http://www.ronenbekerman.com/photoshop-postwork-the-shipyard-breakdown/ http://www.sketchupartists.org/tutorials/sketchup-and-photoshop/sketchup-v-ray-image-post-processing-in-photoshop/ http://www.photoshopsupport.com/photoshop-blog/10/cs5-07/3d-enhance-photoshop-cs5-3d-tutorial.html http://www.ronenbekerman.com/how-to-enhance-3d-renders-with-2d-elements/ http://www.aleso3d.com/blog/tips-for-improve-your-renders/ http://www.cgchannel.com/2013/05/tutorial-post-production-in-3ds-max-and-photoshop/ http://www.ronenbekerman.com/12-postwork-style-architectural-visualization-tutorials/ Edited February 16, 2014 by Ismael Add more info/links Link to comment Share on other sites More sharing options...
jonathanwiederin Posted February 16, 2014 Author Share Posted February 16, 2014 Thank you both very much! Yes the lack of reflection catched my eye too! i`m working on a new rendering now and am trying to fix some problems. Those links are very helpfull too and i sure will find a lot of answers there... regards Link to comment Share on other sites More sharing options...
Scott Schroeder Posted February 17, 2014 Share Posted February 17, 2014 Look at your image in grayscale, then take a look at the histogram. That tells you all you need to know as to why there is no contrast in your render. Your entire image pretty much lives in the middle of the histogram and consists of middle ranges. You have to work on getting your color balancing choices better before you can think to create good images. You can learn all the lighting, texturing, materials, hdri, finding Jesus, etc and you'll still have washed out images if you are using gray on gray on gray on gray on gray color choices. I suggest picking up a copy of this book. Start with the basics, then apply that to rendering. Link to comment Share on other sites More sharing options...
M V Posted February 17, 2014 Share Posted February 17, 2014 Think about lighting, like you would for a real photography shoot. Here is a great article. http://www.popphoto.com/how-to/2013/03/how-to-mix-light-sources-to-warm-interior-photo Link to comment Share on other sites More sharing options...
renatoangeles Posted February 18, 2014 Share Posted February 18, 2014 If you can send the 3d modelling to me, I'll show you how it work step by step. Link to comment Share on other sites More sharing options...
jonathanwiederin Posted February 18, 2014 Author Share Posted February 18, 2014 Thank you very much! I`m working with vray for cinema4d.. what kind of file can i send you? Or are you working with max and we can not exchange files!? regards Link to comment Share on other sites More sharing options...
jonathanwiederin Posted February 19, 2014 Author Share Posted February 19, 2014 Thank you very much! what kind of file would you need? i`m using c4d with vray. Link to comment Share on other sites More sharing options...
atitmistry Posted February 28, 2014 Share Posted February 28, 2014 Hello, Here is the render settings for your scene : http://www.proarch3d.com/common-v-ray-render-settings/ Here is the v-ray materials tutorials. follow it, hope it will help you : http://www.proarch3d.com/category/3ds-max-and-v-ray-tutorials/ Link to comment Share on other sites More sharing options...
jonathanwiederin Posted March 8, 2014 Author Share Posted March 8, 2014 Hey guys, if somebody is interested in my progress, i think i was able to improve my skills a little, i have been working on better texture and render settings For example understanding the specular layer in vray a little bit better. I found 2 realy helpfull free tutorials which are probably the best that i have found for vray for c4d. But sure you can use them for vray for max too. Here are the links: http://vimeo.com/50510866 http://vimeo.com/50507558 The rendering i`m posting is not perfect (plug socket material error etc.), i`m thankful for any critics Link to comment Share on other sites More sharing options...
