New her and need some help image to a plan.
simonrandall
Hi
My first post so please go easy.
I have a PNG image (floor plan) 3569 by 5242 mm.
and I do this:
1, add the image to a material >> Diffuse >> Bitmap >> show shaded material in viewport.
2, add plan to top view >> lenght = 3569 Wight = 5242 >> L Segs = 1 W Segs = 1.
3, drag material on to plan,
4, change wireframe to shaded (top viewport).
5, in object properties >> untick show frozen in grey >> tick Freeze.
6, this is done first units setup >> Metric = Millimeters >> System Unit Setup = 1.0 Millimeters >> Distance From orign = 1.0mm.
Then I go to the top viewport and see the image but the fine details can not be made out, but if I view the image in other softwaer the fine details are 100% fine (even if I put the image in to cinema 4D they are workable) but with 3D Maxthey are not what do I need to do?
Please see attached image (plan scale is 1:100 @ A2 or near as, as it came out of a PDF)
