Boris Horosavin Posted February 22, 2014 Share Posted February 22, 2014 Hi guys, I was just testing Vray 3 for Max 2014 and I noticed a warning about the "bitmap pager" being enabled. Supposedly, it could slow down rendering process. Is this something I should take in consideration? Should I turn it off? Also, as a side question: while rendering an interior scene I've noticed that compiling geometry phase lasted too long (got stuck for a minute or two on a single object). Has anyone else experienced something similar? Thanks. Link to comment Share on other sites More sharing options...
RyderSK Posted February 22, 2014 Share Posted February 22, 2014 You should absolutely turn it OFF. It's rather drastic performance decrease. It's in asset management Link to comment Share on other sites More sharing options...
Scott Schroeder Posted February 23, 2014 Share Posted February 23, 2014 Yep, turn it off. http://jokermartini.com/2013/11/14/render-speed-increase/ Link to comment Share on other sites More sharing options...
Boris Horosavin Posted February 23, 2014 Author Share Posted February 23, 2014 Huh, imagine that... Such a basic thing and I didn't have a clue about it. Thanks guys. Link to comment Share on other sites More sharing options...
iceboydarkb Posted March 4, 2014 Share Posted March 4, 2014 i noticed that in my 3dsmax 2013 files bitmap pager is always off. how come? shouldnt the default 3ds max file have it on? i am happy that it is off. or am i looking at the wrong setting? Link to comment Share on other sites More sharing options...
RyderSK Posted March 4, 2014 Share Posted March 4, 2014 I am pretty sure it's been off either always or for long amount of time. I've heard a scene can turn it on, which would explain why some people have it accidentaly turned on. Link to comment Share on other sites More sharing options...
Guest dialog Posted April 15, 2014 Share Posted April 15, 2014 Where in asset management is this found? Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted April 15, 2014 Share Posted April 15, 2014 ^ Found something here http://area.autodesk.com/blogs/maxstation/n74_using_the_bitmap_pager The value doesn't take effect until the scene is reloaded, so follow these steps: run the following command in the MAXscript listener: IBitmapPager.enabled = false save the file and open it again. Link to comment Share on other sites More sharing options...
