hoanglinh Posted March 1, 2014 Share Posted March 1, 2014 My computer, i7 2640m, quadro 1000m. When i working with large scene i cant see small details. Anyone help me? (with Direct3d 11 recomended) This house is 4000mm x 10.000mm, when i working all city look so sad:( Link to comment Share on other sites More sharing options...
Jose Negrete Posted March 4, 2014 Share Posted March 4, 2014 Check that your model is not located far from the origin point. Perhaps system units should be meters, instead of mm Link to comment Share on other sites More sharing options...
paneli Posted March 5, 2014 Share Posted March 5, 2014 acad-gatsu said: Check that your model is not located far from the origin point. Perhaps system units should be meters, instead of mm +1 Also IMO you should switch to a laptop without this Quadro cr*p. 3Ds Max 2013/2014 works great with GTX. Actually, since I got the GTX I never bother again about scene poly count. I easily reach 12M poly and viewports work like magic. Link to comment Share on other sites More sharing options...
Crazy Homeless Guy Posted March 5, 2014 Share Posted March 5, 2014 You also might want to try the Legacy Direct3d. The Nitrous drivers are rubbish for heavy scenes. Link to comment Share on other sites More sharing options...
Guest dialog Posted March 6, 2014 Share Posted March 6, 2014 Crazy Homeless Guy said: You also might want to try the Legacy Direct3d. The Nitrous drivers are rubbish for heavy scenes. Even with the new K6000 we get the same issues with Nitrous... not sure how many releases it will take to get it right... Link to comment Share on other sites More sharing options...
Josef Wienerroither Posted March 7, 2014 Share Posted March 7, 2014 (edited) dialog said: Even with the new K6000 we get the same issues with Nitrous... not sure how many releases it will take to get it right... Define heavy scene. the quote by "Crazy homeless Guy" is so totally untrue that it really hurts. At least for Max 2014. It's possible that imported CAD data that produces hundreds or thousands of spline segments or seperated objects is really slower in nitrous than in D3D, but in general, Nitrous kicks D3D's butt. Nitrous performance gets influenced by other factors than D3D performance, thus people may come to the conclusion that Nitrous is slower. Get accustomed to Nitrous and how to set it up for best performance and see how it flys... Regarding the original problem: Are your system units set to millimeters by any means ? ( or post suggests this ) This is a general problem with MAx , when the dimension values get really large ( like using millimeters to modell a city on scale ) all possible areas - including viewport get funky , because 3ds Max uses only single precision float values. Switch your system units according to the model dimensions you are going to work with. Meters would be far mor fitting for a city scene ( And don't confuse system units with the display units, which you can set to whatever option you want, those do not influence the inner funtionality/precision of 3ds Max ) Edited March 7, 2014 by spacefrog Link to comment Share on other sites More sharing options...
hoanglinh Posted March 14, 2014 Author Share Posted March 14, 2014 spacefrog said: Define heavy scene. the quote by "Crazy homeless Guy" is so totally untrue that it really hurts. At least for Max 2014. It's possible that imported CAD data that produces hundreds or thousands of spline segments or seperated objects is really slower in nitrous than in D3D, but in general, Nitrous kicks D3D's butt. Nitrous performance gets influenced by other factors than D3D performance, thus people may come to the conclusion that Nitrous is slower. Get accustomed to Nitrous and how to set it up for best performance and see how it flys... Regarding the original problem: Are your system units set to millimeters by any means ? ( or post suggests this ) This is a general problem with MAx , when the dimension values get really large ( like using millimeters to modell a city on scale ) all possible areas - including viewport get funky , because 3ds Max uses only single precision float values. Switch your system units according to the model dimensions you are going to work with. Meters would be far mor fitting for a city scene ( And don't confuse system units with the display units, which you can set to whatever option you want, those do not influence the inner funtionality/precision of 3ds Max ) tks alot, i prefer to work with "mm", but like a city, i should change to "m"? Link to comment Share on other sites More sharing options...
Jose Negrete Posted March 14, 2014 Share Posted March 14, 2014 spacefrog said: ( And don't confuse system units with the display units, which you can set to whatever option you want, those do not influence the inner funtionality/precision of 3ds Max ) ^ Link to comment Share on other sites More sharing options...
