Guest dialog Posted March 4, 2014 Share Posted March 4, 2014 3DS Max or Vray seems to stop the rendering when switching to another program like photoshop (with the performance accelerator enabled). If you switch back to the 3DS Max window it will continue rendering where it left off...I have not seen this issue before... not sure if its from enabling the Performance Acceleration in PS or its an issue with 3DS max or VRay... any suggestions? Link to comment Share on other sites More sharing options...
Matt McDonald Posted March 11, 2014 Share Posted March 11, 2014 What is the performance accelerator? Link to comment Share on other sites More sharing options...
Tommy L Posted March 12, 2014 Share Posted March 12, 2014 I think the performance accelerator is telling PS to use miulti-threading on th GPU but Im not sure. PS shouldnt interrupt the rendering, unless youre using GPU rendering. Simple fix would be to use a different machine/s for rendering, which is good advice whichever way you cut it. Link to comment Share on other sites More sharing options...
hrishikeshp Posted March 13, 2014 Share Posted March 13, 2014 Hi Desmond, I faced this same type of issue. The solution was, don't do anything when your render in progress. I have Processer I7 3.4 GHz, 8 GB ram and 2GB graphics card.. then also i faced the same issue. The Adobe products like flash illustrator photoshop are heavy for processor. I also try better solution for the same issue...!!! Link to comment Share on other sites More sharing options...
