Revit to 3ds max lighting problem
antwoinegilbert
Hello I am having a problem with my 3ds max scene and was wondering if anyone could lend a hand. I have modeled a scene in revit and imported it into max. The storefront windows have a revit material on them and it renders fine. But when I set the window panes to a vray glass material bright light comes out from the windows and destroys my scene.
VRay is not compatible with "Autodesk Materials" different of Arch & Design Materials, or pro materials. Latest REVIT release only use Autodesk Materials, so you need to convert those materials to VRay materials. It is not the glass or transparency issue.
Not sure if crack version will have this problem, but valid point too.
