muhamedthufail Posted March 11, 2014 Share Posted March 11, 2014 Hi , Am working on a project in which i have to model this commercial building. Am not able to see the wireframes from a certain distance. Am attaching the images for reference. Is there anyway to increase the thickness of wireframe ? or is there any other way to rectify this problem ? thanks in advance .. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted March 11, 2014 Share Posted March 11, 2014 The 3ds max viewports suck, and always have. Switch to Orthographic view (U on keyboard), that should help rectify the problem. Link to comment Share on other sites More sharing options...
Josef Wienerroither Posted March 11, 2014 Share Posted March 11, 2014 Look at your scale: you seem to work with pretty high numbers as the transform edit fields in the status bar hint ( like working in mm to build a large building or build far off the origin ) hence your perspective viewport gets all this wonky stuff including wireframe falling behind their faces etc... either switch to orthographic, like suggested or work with adequate system unit settings Link to comment Share on other sites More sharing options...
muhamedthufail Posted March 11, 2014 Author Share Posted March 11, 2014 Thank you both .. I didn't do much modelling. So i tried the scene with meter as the unit. Now everything works fine. Thanks again .. Link to comment Share on other sites More sharing options...
