hockley91 Posted March 20, 2014 Share Posted March 20, 2014 I don't think I ever had this problem before and I just can't think of how to fix this issue... Sometimes I region render multiple areas that I fix in the model. Well, once I render a region, I'll render another region and another. The previous region renders always stay there and I kind of build up the render layer by layer. Well, for some reason it will only region render two times while saving the previous renders. Once I render a third time, the render window resets and it all turns black and will region render the next selection. I have no idea why this is happening... I've switched to the vray frame buffer for now and I can region render no problem. It does not reset the window. Any ideas? Thanks Link to comment Share on other sites More sharing options...
Tommy L Posted March 20, 2014 Share Posted March 20, 2014 If you are using Vray then you should use the VFB anyway, so maybe max was just trying to tell you something. Link to comment Share on other sites More sharing options...
hockley91 Posted March 20, 2014 Author Share Posted March 20, 2014 If you are using Vray then you should use the VFB anyway, so maybe max was just trying to tell you something. Depending on the situation I use both. In this situation I'm using the Max Render Window because I have a "glow" effect I need for a light fixture. Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted March 25, 2014 Share Posted March 25, 2014 Same problem, after 3-4 regions, the base image is gone...bad....for detail corrections.... Link to comment Share on other sites More sharing options...
hockley91 Posted March 25, 2014 Author Share Posted March 25, 2014 Same problem, after 3-4 regions, the base image is gone...bad....for detail corrections.... Exactly! Right? What the heck is going on? Link to comment Share on other sites More sharing options...
hockley91 Posted March 25, 2014 Author Share Posted March 25, 2014 Well, what I ended up doing was just rendering without the "Glow" effect. I just isolated the object I wanted to glow. Rendered it by itself with an alpha channel and just layered it in Photoshop and did it in there. Worked just fine this way... Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted March 25, 2014 Share Posted March 25, 2014 Some bug, I think. I did not noticed this in previous versions, but to be honest, I didnt even think about this. ... ^ Do you use VrayWireColour render element or Cebas PSD manager for that channel/layer/cliping? It can be very helpful... Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted April 17, 2014 Share Posted April 17, 2014 ...if you CHECK ON, distrubuted render in Settings tab of Vray, it will save previos image with render region. Not proven for 100%, but for now it is, I'll check on later. BUT, with this function on, it will slow down of starting render, looking for local machines, saving file, etc... Link to comment Share on other sites More sharing options...
