Good old xaml error...
alexandrapopova
Hey guys, I'm sure you're fed up with threads like this, but apparently I'm a complete computer imbecile... The problem is the same as always "Error parsing Xaml file: Root element is missing"
I read hundreds of threads in different forums and none of them seemed to work for me...
OK, First I made all the hidden files visible, THEN I located the enu folder in App data/Autodesk/3ds max , but it contained only the file ProdDep_UserDep.mc3
I'm getting a little confused here, because I read that the enu folder is located in the UI folder. But my UI folder is in a different place: Program files/Autodesk/3ds max
I suggest this is the folder I should be looking for because it contained default ui schemes and xaml files. But I still couldn't find the Maxmanaged.xaml file :( Nevertheless I deleted all the files (copied them to another location), but it got even worse... everything was gone and max turned white... I reinstalled it, but nothing happened. Am I blind? Please help me :)
Ismael Orozco! Big up, man! I just can't believe I wasted so much time on this, but finally it's solved! The problem was the directory I was searching in... Apparently there are max files all over the place :) Everything is just as it's described in the thread, you just gotta keep searchin' :) Thanks guys, you can lock it now
