jamisonlb Posted March 26, 2014 Share Posted March 26, 2014 I have a client wanting a spiral/helix shaped chair in their waiting room image and im having trouble modeling it. The chair has pads that fallow the curve of the wood but are all different sizes. Ive drawn a helix and used lofting of a couple shapes to get the general shape of the chair but the front lip of the chair is rounded and curved and im not sure how to achieve. Also im at a loss for how to get the pads to fallow it and change sizes. Could i model this thing flat and then do a helix deformation on it? Or how to round out the lip of the wood without deforming the vertices? any help would be great. cheers Link to comment Share on other sites More sharing options...
Jose Negrete Posted March 27, 2014 Share Posted March 27, 2014 check out this vid. Link to comment Share on other sites More sharing options...
Ismael Posted March 27, 2014 Share Posted March 27, 2014 Judging by the first image here http://hungarian-success-stories.com/2012/09/26/hug-chair-by-gabriella-asztalos-3/ all the pads appear to be the same size. I would love to render that chair if only I could model it. Link to comment Share on other sites More sharing options...
Scott Schroeder Posted March 27, 2014 Share Posted March 27, 2014 Create it flat and low poly first. Move the verts at the ends to create the rounded shapes. Create the pads. Turbosmooth as needed. Then use an FFD to get the hourglass shape, then use a bend modifier to wrap the surface. Once you have it bent you can either modify the previous FFD or add a new one in to pull the ends apart to get the loop the loop look. You could also try using a path deform with the helix shape and deforming your main chair geometry, but I was getting some weird twisting when I ran a quick test. Link to comment Share on other sites More sharing options...
Ismael Posted March 28, 2014 Share Posted March 28, 2014 Tried somewhat Scott's suggestion and got this far. I don't seem to be able to correctly separate the seating areas. Link to comment Share on other sites More sharing options...
Ismael Posted March 28, 2014 Share Posted March 28, 2014 Better results after re-reading the instructions: Link to comment Share on other sites More sharing options...
Jose Negrete Posted March 28, 2014 Share Posted March 28, 2014 looks good. wonder if jamison was able to do it. Link to comment Share on other sites More sharing options...
Ismael Posted March 28, 2014 Share Posted March 28, 2014 I had to try and sit someone on it: Link to comment Share on other sites More sharing options...
jamisonlb Posted May 19, 2014 Author Share Posted May 19, 2014 thanks a lot guys. I have gotten pulled off this project onto a few others and havnt had any time to mess with it. Will hopefully be giving it a good shot in the next few weeks. I'll let you know how it goes. thanks again. Link to comment Share on other sites More sharing options...
