nVidia quadro K4000 or GeForce GTX 780 Ti ?
Hi all,
I have a dilemma about choosing the video card for my pc.
The configuration of the pc is: i7-4770 3.4 GHz, 16 gb RAM 1600 MHz, 250 GB SSD.
I want to use it for photorealistic rendering in 3ds Max, VRay and Lumion. I read pros about both cards, but i can't decide which would fit my needs better.
Thanks,
Robert
[sometimes I click "Go advanced" instead of "Post reply" and I loose such long messages....like damn it, idiotic system, or maybe I am blind idiot....but.....duh]
Ah, well anyway....in super shortened version, I know Dimitris will write the full-lenght maybe and you will get hence few opinions:
Proper question would look like this instead: 'Viewport performance' for '3dsMax 20xx' / Vray 'RT GPU' / Lumion. Makes a big difference.
Clearcut answer to that would 780 6GB. No energy to write the rest, but this is it.
Long winded post on this matter cannot continue!
The Quadro niche is diminishing with most applications, and 3DS was one of the 1st to work great with GTX - has been the case for at least 2-3 versions.
Many claim that with very-high-poly scenes, Quadros maintain an advantage, but that many 100s of millions of polygons are simply outside my interest atm, and if I ever get to something like that, I would be using layers and/or proxies to simplify what I see on screen anyways.
Within this context (which is important), the perceivable viewport performance you will get with a 780Ti, will be available to a 780.
If you plan on using some progressive renderer, I would consider the 6GB version that has been announced.
Otherwise, the 3GB ones should be enough for pretty much anything viewport-wise. Even with 4K monitors.
In my office atm I am using Revit 2014 daily, which I suspect utilizes a similar (tho far more CPU bound) viewport degradation approach with 3DS.
I cannot really spot a viewport performance difference between systems that use K4000 and GTX660.
Btw, out IT dept doesn't really care about my input.
Edited by dtolios
