cannot create button for a script
carlonarducci
this error when I set rock generator on stdscript folder and I create a text file with this script
macroScript RockGenerator category:"aa_stoneworks" buttonText:"RockGenerator" toolTip:"Rock Generator" silenterrors:true
on execute do(
filein ((getDir #UI) + "\\MacroScripts\\aa_rockgenerator1x0.mse")
Get aa_rockgenerator1x0.mse and place it in maxRoot/scripts folder. Usualy:
C:\Program Files\Autodesk\3ds Max 2014\scripts\aa_rockgenerator1x0.mse
Then use the code below to create a macroscript.
   rockGenScript = (getDir #scripts) + "\\aa_rockgenerator1x0.mse"
   if doesFileExist rockGenScript do fileIn rockGenScript
Edited by miauu_u
It works, believe me.
Put the mse in the maxroot/scripts folder. RUn 3dsMax, open the maxscript listener, paste this:
Press the NumPad Enter and in the next line you have to see the full path to the file, which in my case is:
"C:\Program Files\Autodesk\3ds Max 2014\scripts\aa_rockgenerator1x0.mse"
If this is not printed, I mean the full path, then the aa_rockgenerator1x0.mse is not in the proper folder and this is the reason that it is not started when you use the macro script.
  • 9 months later...
1° Maxscript - Run Script. Then browse your "aa_rockgenerator1x0.mse" wherever you saved it - Window with the aaRockGen - 1.0 will appear
2° Do NOT close the script window
3° Customize - Customize User interface - Group: Main UI - Category: aa_stoneworks - Action: Rock Generator
4° Click on "New" and name your toolbar. Then drag Rock Generator from the Action list to the new window you just created.
Just be aware, if you close the script window, aa_stoneworks won't appear on the category list.
