Chamfer sketchp model imported into 3dsmax
liorsturlesi
You can chamfer the imported model if rightclick on it, then select edge mode, then select desired edges right click chamfer.
I suppose you should rightclick and convert to editable poly first though.
Strange that the chamfers disappear, I use the "round corner" sketchup plugin a lot since it imports fine to Max with same vertices amount as Max chamfer.
Make sure your SU geometry is tight and solid. I suggest a plugin called Solid Inspector by Thom Thom (great plugin). Nonetheless you might get un-welded vertices.
As a rule of thumb, every time I import SU in Max, I convert everything to EPoly and upon first selection for each object I weld vertices and clear smoothing groups where necessary. Takes only a few seconds.
Edited by salvador
